Weliketomoveit
- Jul 14, 2015
- 6
First time poster long time reader.
So after hours of reading hundreds of post on this subject I am stumped.
Recently purchased a 1965 MFG Westfield Custom with 1965 mercury 65 HP outboard Kiekhaefer 650 4 cylinder. All original one owner garage kept with documentation. Performed all the usual/required maintenance items. Motor runs and works great. Time for the impeller replacement:
Removed lower unit ?IN NEUTRAL?
Installed new impeller
Could not get lower unit to line up by myself after trying for hours. This is where things get a bit foggy:
Eventually got unit to within 3/8? and tightened it up from there.
Ran engine and only had ?Forward Gear? Removed lower unit, moved shifter to forward and reinstalled but no change.
Eventually discovered that ?shift shaft? had popped in to forward. Rotated shift shaft counter clockwise and tried every possible combination of installation of F-N-R with the shifter in the correct position. The best I can achieve is ?Reverse with Neutral? or ?Forward? only. I also seems that I have to disengage or reengage the shift linkage and/or move the shifter to get the lower unit to slide all the way in.
The only thing I can add is that at one point I had neighbor come to move the shifter and heard a ?clink sound?. I do not recall if the lower unit was on or off at the time or the direction he moved the shifter. My concern is that I may have bent something.
I can get the ?shift shaft? to engage F-N-R
I know this topic has discussed hundreds of times. This is not my first boat nor my first impeller change. If anyone can point me in the right direction I would really appreciate it. Thank you
