67Mustang-man
- Jun 2, 2015
- 15
So last weekend I had some issues of the engine bogging out at 2-2500rpm and at best 5-7mph I haven't had much time to really dig into the carb system on the engine, I have installed a new stator, trigger and regulator on this motor. Here is what is happening now, I sprayed some cleaner into the carb, blew out the jets and now I can get it to 4k and at best 25mph. If I push the stick I can feel it want to take off like the there is torque there but it will almost stall out if I go to fast. A slight fast bump will toss you back a bit but to fast it will stall, If I ease into it I can get it up to 10mph if I have someone sit on the bow seat it will get to plane and hit 25mph
Am I asking to much for this motor or could I be missing on 1 or two cylinders, it does have a bit of a rough idle but I don't know if this is normal for two strokes. With all the poor electrical issues these motors at this time were plagued with could it be bad coils? All I can be left to is coils or low compression.
Total weight boat plus gas gear and people 1500lbs the boat max capacity of people and gear is 1050, I am not sure if that means gas as well but with 1500 is everything and if you take out 617 dry weight of the boat that puts me at max. The boat is a 1976 Monark Mcfast 5 "Mcslow"
