tiffany111786
- Jul 10, 2015
- 4
We recently purchased a used 2007 Mercury 115hp 4stroke engine. We knew the engine was blown, are hoping to rebuild. When we got it home and put on a stand, we were able to finally see the full extent of the damage.
The bottom cylinder piston connecting rod snapped, and blew a hole around the entire block. Blew the oil filter off, and blew a hole all the way around the crank to the opposite side of the engine. We are hoping to rebuild it, it is too new of a motor to find a rebuild one, so we may have to start with a empty new block. How do you tell if a crank is still good or should we just replace it?
Just wanted some input on what may have caused this to happen? We have no info from the previous owners.
