I have a 2001 Mercury 50hp ELPT 4 stroke . I don't know too much about outboards . We bought this boat about a year ago used. The motor starts great and it was a little rough around 3000 but usually runs well around 4500/5000rpms tops. The last couple times we've had it out its been rough running on 4200 tops. Its to the point now where it doesn't want to run any higher than 2500 and when I try to give more throttle it starts to die out . There was a steady beep when it started to die and it stopped when I throttled down. There was a steady water flow from the engine while running and I checked the oil level which was fine. Any idea on what could be happening?
