paulywally
- Mar 6, 2011
- 39
Trying to figure out my problem on a 1994 Mercury 40 hp 4 cylinder. I replaced a piston and got all the cylinders honed by a reputable machine shop. I put it back together and used "loc-tite high flex form in place gasket maker" http://www.henkelna.com/product-search-1554.htm?nodeid=8797881860097
So it ran great for about 5 minutes on the muffs. Checked compression and had an even 130 psi across all 4. Took it out on a little fishing excursion and after 5 minutes under load it died. Took it home checked compression and compression was between 80 and 100 psi uneven across cylinders.
Now I know this sealant is an anaerobic sealant which means it won't unless there is an absence of oxygen. I do have uncured sealant on the outside of the cases and I did allow sufficient drying time.
So compression is low, at first I thought it was a fuel problem but I took the carbs apart and they are working properly. spark plugs aren't wet, and have spark.
So will a failed crank case seal cause low compression? I'm having trouble remembering my two stroke theory properly to figure it out myself.
Any words of wisdom?
Thanks.
Paul
Thanks.
Paul
