Ok, I know what everybody's thinking, he put it together with the lower unit in in the wrong gear compared to upper unit. I checked, double checked and checked again. It shifts through all 3 gears just fine. In forward, it does not turn cclockwise. In neutral it spins freely both ways. In reverse it clicks both ways. If I turn flywheel by hand in reverse it turns it, but I can hold prop from moving while turning flywheel?? Any help would be appreciated.
