Put boat in the water this year after a hard start it would idle fine but when put in gear fell onto its face. Pulled back to garage and cleaned carbs and Checked spark and was only only firing on cylinders 1,2,5,6 Installed new stator, trigger, and rectifier The spark is constant on cylinders 1,2,5,6 Changed cdi and now only have it on 2 and 6. Changed out battery with a brand new one I had because that some times can cause erratic spark. Has new water pump and newer coil and plugs
At this point I'm clueless on what the issue is any help would be great!
