jamesmillus
- Jun 20, 2015
- 5
I just replaced my wire harness and throttle, that connects to my 76 Mercury 1500 150 hp, I hooked up the control cables and got it to run relatively smooth. In neutral it runs and the prop is moving a bit fast, forward runs good but no stop when i bring it into neutral so that it can go into reverse. and no revers.I unhooked both cables and in neutral it only goes one direction i believe it to be forward (clockwise) with a clicking and no reverse on reverse the same thing and of course forward the same thing. After reading some of the other post I'm thinking I need to take apart the lower end.
