Could be many things. Sounds like a fuel issue though
All the things you had done was to solve the issue, or did the issue start after you did all those things?
Your right the engine does not have a choke as such, but I think enginepower was talking about the enrichener system. If yours is the same 90 HP 3 cyl engine as mine it's not automatic; are you following the correct start procedure : primer bulb hard, fast idle lever set 1/2 way, turn key to crank the engine then push the key in into "choke" as it's cranking. - Do not let crank for more than 10 seconds, give it 30 seconds break before trying again). If everything else is OK engine should fire right up,
Here is a nice list of other possible problems
1 Fuel tank vent closed / blocked.
2 in line fuel filter / water separator / fuel pick-up in fuel tank blocked.
3 Loose hoses especially in combination with 1 and 2.
4 Old Fuel lines failing / restricted on inside.
-- install a clear plastic pipe between fuel pump and 1st carb, crank the engine and see if your pumping fuel or if your pumping air bubbles / also try running from a separate fuel tank. If bubbles find and repair the blockage / leak.
5 Enricher valve not functioning - check engine makes a clicking noise when the key is pushed in, if no clicking noise can be heard the enricher valve has failed / is not connected and will need fixing. If you can here a clicking noise remove outlet hose from enricher valve and place suitable container to catch the fuel under the outlet, push in key and check fuel flows from the valve to check it's working properly.
6 Do you have an Anti-siphon valve? If so remove it and see if there is a difference
Here are some other things which might sound dumb but you never know.
Throttle not set up correctly, the cam on the center carb "overcentering" so all the carbs do not close from the wide open position (this happened to me once) :blue:
Carb's are in sync with each other, they all open and close with each other and by the same amount.
Have you checked the ignition timing
Kill switch not in run position, happened to a mate of mine once and he called for a tow home :laugh:
HT leads not connected to correct plugs.
Low speed mixture screws not set correctly (should be 1 1/2 turns out from lightly seated for initial start-up following carb re-build)
Good luck.
david
