longshanks
- Jun 12, 2006
- 188
Father in law just bought a very nice, low-hour 2006 Merc 4-stroke 9.9. Starts and runs like a top and the mechanic that inspected it prior to our purchase gave it perfect bill of health. Problem is, after running for somewhere between 10 minutes and half hour, it stalls. Pumping the bulb will prevent it from stalling. I tried swapping out his tank and line with mine, but same problem with both tanks. We are using fresh fuel and the plugs, fuel filter, all look clean. No obvious kinks, holes, etc in fuel lines in motor. It seems like it is not pumping fuel into carb. By manually pumping fuel with the bulb, it will run forever. The mechanic that inspected it is 00s of miles away, or we'd take it back. But I think this could be a simple problem and so checking in with some of the old pros here first. Any suggestions?
