sptjet90Reflexx
- May 28, 2011
- 383
Working on my neighbors bass boat. When in N it will rev up fine. Once in gear it will have no power and die.
Tested using external tank and new fuel hose/primer. Running Pre-mix.
Compression is 120 on all 4.
Fuel pressure is around 6 PSI at idle and goes to 10 PSI when rev.
Stator/Regulator is charging at 12.7v and up/down as would expect. Increases as RPM increases.
New Spark plugs.
Verified spark to all 4.
Put a timing light on it and #1 kicks around a little while 2/3/4 seem to be ok.
My guess is the switch box. Not sure what else it could be.
Thoughts?
New Spark plugs.
Thoughts?
