thanks for the help, i did replace the impellar, was really bad. went to lake with high hopes that problem was resolved. However,I was used to squeezing the bulb alot to prime engine to start, but as stated previous;y I found sediment in the fuel pump strainer. Well when I fired up the engine I had a fuel fire ! Grabbed 1 of the 3 fire extinguishers and was not smarter than a 5th grader because after pulling the pin I could not get the extinguisher to work. Threw it down and unpluged fuel line, and proceeded to splash water on the fuel fire in the outboard!!!! went home very sad, tried to start it and nothing, spent last 2 days resolving all those issues. TODAY< got the engine back on the lake and started, no fire LOL !!! I am still stressed ouit over that ordeal!! Well, to my demise I am still back at square one, sme original problem starts, idles, but when put in gear the boat goes only 5mph, When given more throttle it will bog down and die without any acceleration. I will look at the carbs in the next few days, I have read in other posts people seeming to have similar issue and turned out to be the high speed stator windings? any thoughts?? thanks!
