Question, what grade of silver solder are you using. I was doing a little studying on the subject and the different melting points are graded as "easy", "medium", "hard", etc. I reckon it would make a difference! I'm thinking you don't want to get the shaft too hot, as to avoid warping.
When I had my old machinist weld-repair shafts, he always had to straighten them afterward 'cause the welding would warp the shaft. They sure were nice when he was done, though! Sadly, he passed on a few years ago and I've found no one in the area with his expertise.
The lower-temp repair sure seems like a good way to do an economical fix and I'd expect the repair will last the life of the motor!
Thanks..........ed
