Oldmanskier
- May 27, 2015
- 2
I am having a problem with my mercury 140. It starts fine and runs at high rpms fine . After it gets warmed up it seems to flood/choke out when you add in power even slowly. Hard to get it to plane. If you get it up thru medium rpms it will plane out and runs fined. Had carbs rebuilt, new plugs . Seems to me that it could be a timing or distributor adjust. No one in my area works on these older motors as the motor is older than most of the mechanic, any help or advise would be very helpful.
