scrapper042000
- Apr 14, 2015
- 70
i need an opinion guys ,I have a boat in the shop with a 45 hp merc 4 cylinder (1986) ,owner said the boat would bog down and run rough at times ,while checking the motor I sprayed carb clean along the left side of the engine block at the split where the 2 block halfs join as I spray carefully on the seam the motor bogs down and will kill ,I put some rags to avoid drift to the carbs and no matter how carefull I am. it is definitely drawing air in at the block seal ,my opinion this motor needs to come apart ,I also notice no spark at #2 cylinder (presuming switch box ) I just feel the motor should come apart because of the crank case drawing air ... any opinions guys ?
