I am buying a used boat with a 2006 Mercury 90 HP 4 stroke EFI, and will have a compression test done.
I believe, for reading here, that nominal compression should be 138 psi.
- is above compression figure correct?
- how far off could it be, and still be acceptable?
- acceptable variation across cylinders?
(I will have a question about basic initial "looking things over, getting to know your motor" in another post)
