1997 Mercury 150XL S/N OG571840
Does anyone have a wiring diagram for this engine? I think I have a power pack that has failed. As soon as I fire up the engine, the warning horn rapidly beeps on and off. I?ve checked everything that would cause the alarm including:
Secondary oil float reservoir-checked ok
5volt pulse from oil pump-checked ok
*** Temperature causes a solid tone alarm condition(I think)?
While cruising, engine will not run over 2k RPM.
The only thing I didn?t check is signal from Power Pack to warning module. I understand this could cause the alarm if power pack is faulty. Interestingly, it doesn?t appear to monitor both Power packs? Does it only monitor 1 Power pack? I would like to know the process involved in testing the power packs to ensure proper operation.
Thank you for any input provided!!!
Dale
Dale
