Hey everyone!
I recently purchased a 1989 Landau 15 flat bottom boat with a 9.9 mariner on the back. I believe the motor is the factor motor that came with the boat so i am making the assumption the motor is also a 1989.
When i start the motor at idle the water trickles out of the hole then stops - however when in gear and running the water pushes out a nice steady stream as it should. My question is should the pump push a nice steady stream of water at all times even in neutral or at idle? Or is this operation correct? i have also read on here that it may take ~5 minutes for the vavle to open to start the water stream. I let the motor run at idle for about 5 minutes with no sucess but when in gear and running the stream is nice and steady.
Any help would be appricated!
