Hello,
I have been having an issue on the water and I can't seem to figure it out and hopefully with your advice I can get my boat up and running. I have a 1976 Glastron T166 Xl with a Mercury 850 outboard. I am having issues with the my boat turning over. At times I have power other times nothing. This only seems to be the issue on the water and have never had the issue when running it on land with the muffs. I don't know a lot about boats and learning more everyday. I have tested the neutral safety switch and this seems to be working fine. I also cleaned and used dielectric grease on the battery connections. When I turn the key over at times on the water I hear nothing not even the choke engaging. I open up the cover and see the starter and the starter solenoid is there anyway to trouble shoot those to items. Also is there a way to trouble shoot the pin connection on the side of the motor where the boat wires go to it? How do you open that connection does it just pop off. Also is there a way to trouble shoot the wire inside the boat connection that runs to the MerControl throttle box? I am running out of ideas and look forward to any feedback. Thanks
