Rewiring an older pontoon and it has 6 wires coming out of Quicksilver control.....White with blue stripe, Brown with white stripe, Purple, Gray, Tan, and Black. What are the functions and where do they go? Also has a Nissan tach with only two wire coming out of it...Yellow and White that are sealed going into the unit. How is this suppose to work or be wired? Thanks!
I just purchased a used boat that wiring was garbage. Down to the Small harness out of control which has 6 wires..White with blue stripe, Brown with white stripe, Purple, Gray, Tan, and Black. Where do they go and what is their function. Also it had a Nissan Tach with only a white and yellow wire coming out of it. No place to plug any other wires to. can someone share some knowledge on this? Thanks!!
