OK, First step in link and synch is to set the timing pointer correctly. Remove all spark plugs. Stick a dial indicator into the top cylinder. If you do not have a dial indicator, use a steel ruler or caliper. Set the piston to top dead center. Measure from water jacket cover to top of piston. Add .464 inches to that measurement. Turn the motor CCW 1/2 turn. Stick ruler into cylinder to sum of measurement. Turn flywheel CW until it hits ruler. Now piston is .464 inches before TDC. Set timing pointer to agree.
Now install top spark plug, and attach plug wire. Stick other plugs into their wires and tape the bases together and ground the bases to the block. Advance throttle until the carbs are ready to open, but still closed. Attach timing light to top plug wire. Crank motor and observe timing. It should be 2-9* ATDC. Adjust the primary pickup screw (on the throttle arm, just above the pivot point) to make the pickup timing correct. Note: you may need to adjust the idle stop screw (bottom most screw on throttle arm) and the throttle cable barrel nut to make this happen.
Next advance the throttle all the way and crank motor to find timing. Max spark advance should be 21* BTDC. Adjust the max spark advance screw (top most screw on throttle arm) to make it correct. Adjust throttle stop screw to stop the throttle open before it hits carbs stop. Throttle stop screw is below pivot of throttle arm, on the block to the left of the throttle arm.
That is it....
That is it....
