To set the timing belt, remove the 5/16" bolt from the distributor pulley. Now remove the timing belt from the pulley and turn the flywheel until the dot (or three dots depending on year) is closest to the distributor pulley. Now adjust the flywheel and cast arrow on the distributor pulley until it points to the dot(s). Install the timing belt. Check spark at the coil first. If you have it there, then check for spark at the plug wires. Wires unscrew from the distributor cap, and pull out of the coil.
