hi guys, i had a merc stack 6 on one of my boats and the throttle setup was spot on but the ob died so i replaced with a similar aged merc 50 4cyl. i put the throttle cable in as they were and the went in fine. unfortunately a few bolts sheared when doing so so they are almost permanent/long job to adjust ob side now.
So the problem is my acceleration jumps so there no power until 45degrees on the throttle and i have to go past 90 degrees for wot, and the power jumps in stages not smooth like it was. can i adjust cables at control end? and which way would i adjust? also when backing off wot it jumps massively down... cheers
