I also bought this boat with no knowledge on the Shape of the motor. All the info I know is it was last reg. In 2008 set in a field after that until 2013. Has good compression. Started is good. Timing is good. Tore the lower unit apart cleaned it up everything seemed fine there. Has some kind of weird spark plugs. I tried to get spark by grounding it out nothing happened. It did not have a throttle and shifter when I got it. I had a Tohatsu one laying around the power cables don't match the motor. Where can I find these? I also am looking for a wiring diagram or manual. All the wire covers were brittle and falling apart. I am new to outboard motors. Thanks guys. Serial number 4074716
