I have been working on a 1995 mercury sportjet 120hp and have good spark and compression on all cylinders. The engine hasn't been running very good and after doing tests I found out that the bottom 2 cylinders are not getting fuel, since the spark plugs are dry. This leads me to believe something is wrong with the bottom carb. I have recently cleaned both carbs but am currently re cleaning the bottom one. When I took the carb off the motor, the bowl was full of gas, so it is getting fuel inside of it. I'm guessing its one of the jets but the all seem clean and clear of debris. Another thing I have noticed is if the engine sits for a day it will fire up the first time almost as if a bit of gas moves into the cylinders slowly, but once it starts and that gas it burned up, the carb wont supply it with more fuel. Any thoughts?
