steve mcintire
- Feb 10, 2014
- 39
My 96 60 hp tilt unit will raise up about half way and stops. The motor begins to make to make a more high pitch sound. I can lower the
unit a little and the cylinder will raise up an inch or two, and it stops upward movement again.
The unit jerks while traveling down a little but otherwise works. The cylinder does not leak externally and will stay up fine when under a load.
I priced a new unit and that is not an option.
Any input would be great. Thank you in advance
Steve McIntire
Steve McIntire
