Is there a way to check the hours on an outboard. without taking the whole motor to the shop?
jerryjerry05 Supreme Mariner Joined May 7, 2008 Messages 17,926 Apr 26, 2015 #1 Is there a way to check the hours on an outboard. without taking the whole motor to the shop?
Faztbullet Supreme Mariner Joined Mar 2, 2008 Messages 15,616 Apr 26, 2015 #2 If you got a Merc diagnostic tester you can....
jerryjerry05 Supreme Mariner Joined May 7, 2008 Messages 17,926 Apr 26, 2015 #3 Nope. If I took just the ECM in would they be able to tell with that? I just don't want to lug that BMF around again unless it's going away!! Thanks!
jerryjerry05 Supreme Mariner Joined May 7, 2008 Messages 17,926 Apr 30, 2015 #4 Found the answer. Sent Mercury's hot line an e-mail. They called back within an hour. They said no. has to be on a motor. So it's off to the dealer I go. Last edited: Apr 30, 2015
