Charging system
gstuck1956
I now own a 2002 Merc 150XL saltwater...who can tell me where I can go to find out if it has on board charging system for my batteries? Thanks
roscoe
Welcome to iboats.
it does.
Whether it is working or not is another question.
Silvertip
Does the boat have a voltmeter on the instrument panel? If so, what does it read engine off/key on and again with engine running at 1500 - 2000 rpm. Presence of a voltmeter says there is a charging system. What the voltmeter reads tells you whether or not the system is working. Static voltage on a charged battery will measure about 12.6 volts. That same battery measurement on a running engine should read about 13.5 - 14.5 volts. If the reading stays the same in both conditions and is less than 12.6 volts and drops below that when accessories are turned on, then the charging system is not working.
