Mercury Mark 58A Lower Unit Oil
superrman77
Guys I have a 1958-59 Mercury 45hp Mark 58A on my Boston Whaler 13. I didn't get it out on the water last year but I started it up a couple times. Today I fired it up. I decided to change the lower unit oil. It drained out slow and I noticed the oil was milky. I changed it with Mercury 80-90 weight oil. I ran it for a bit and changed it again. It was milky again. Is this normal on these old motors? I also noticed some seepage from these holes on the side of the case. Should I take it to the lake and run it and check it again? Or do I need seals?
merc850
Those are water drain holes but in your case the seal(s) in the waterpump and driveshaft are leaking oil and/or the washers under the oil fill screws are missing. It is not normal. It's a good time to replace the waterpump impeller too. Parts here http://store.oldmercs.com/category_s/716.htm
superrman77
Can you help me out with the part numbers merc850? I am a rookie at this. Taking it to a shop is out of the question right now. Any special tools needed?
Thanks
Mi duckdown
what does your driveshaft look like at the water pump seal. back then they rusted and pitted. carbon steel.
merc850
That link I gave you is to a site that has the parts manuals etc. the next page has the complete LU seal kit. If a Mercury dealer will undo the WP cover and pull the pump housing it will save you a lot of time. One thing that's easy to check is the shift shaft seal see dia. M58-impellersmall.jpg
this site is for older Mercs http://johnsoldmercurysite.com/phpBB3/index.php
