So when I start the engine the bottom carb drips slowly and then when I turn it off the top 2 start dripping. Can anybody tell me what the problem is or how to fix it? Also when hooked to a hose it wont pump water out in idle but if I give it gas it comes out pretty strong, a guy at work said that his boat wont pump water at idle on the hose either. Is that normal?
