serial number 0B277848
I took what I believe to be the main jet screw off the carbs to inspect, it has a number on the tip of the screw says 0.74 if I recall correctly, now the gasket seal is torn and I don't have a replacement at hand for it, not sure if my local parts dealer have it in stock as wel, can I use any gasket to replace as long as its the correct size and it seals? does the jet screw have to go back in a certain way or just screw back in and tighten up?
also looking to do a taredown of carb later down the road, its been running kinda sluggish on top end, if I just wanna take off carbs to clean al I would need is to just get the gasket kit right? unless I find other things inside carb in bad shape then of course I would need to replace those bad parts aswell?
its going to be first attempt at taking off carbs, is it quite difficult task? do I need to do a link n sync on the throttle arm after finish re installing the carbs back on?
