fishfeatures
- Mar 29, 2011
- 743
'79 200 20hp, after i changed the water pump in it, the gearbox has been going me issues. the shift shaft will turn if i put vice grips on it and the prop will turn if i turn the drive shaft.
however once i attach the lower unit , the selector on the motor won't shift into reverse, reverse gear is now neutral.
I noticed the the reverse lock wire? was out of place so i put that back in correctly so when the cam moves the wire moves too, but still reverse gear won't engage.
when i start the motor it also won't start as neutral is now in forward gear...
i'm a bit puzzled , is there a chance that where the shift rod mates with the cam in the midsection, that this is worn ? could this cause the issue or should o pull apart the gearbox??
