Outrageous One
- Mar 5, 2015
- 4
Engine starts easily when cold and runs flawlessly. After the engine sits for a while, it will restart with no problem, but, after several minutes, it will start to race like it is running lean, (running out of fuel) sputter and die. It will restart and immediately stall out. Squeezing the bulb the first time resulted in a momentary restart and then it stalls again. Pump the bulb again and it restarts and runs flawlessly. Replaced the bulb, fuel water separator, and hoses without curing. I tried to pump the bulb as it was starting to stall, but it still did. I tried pumping the bulb before starting and it still stalled. It always starts after pumping the bulb after the 2nd stall, but never after the first stall. It acts almost like engines from the 70's would do when they vapor locked. High pressure pump has been replaced.
