william haynes
- Aug 31, 2012
- 35
I have a 1987 115 hp mercury outboard. the motor blew up so I found a good deal on another Mercury except this one has a long shaft instead of a short shaft. It goes on a 18 ft. bass boat. I installed the motor on the boat and it runs great. the only problem is if I start to trim the motor up it starts porposing and I have to lower the motor full down to keep it from porposing. runs great at full throttle but I can't use the trim. I know this boat should have a short shaft but got such a good deal on it couldn't pass it up. Anything I could do to correct this problem? Thanks
