Mercury 4Stroke EFI BigFoot 50 hp 2006: The RPM vary and then the engine stalls when I try to set the RPM between 1000 and 2000. It runs great at idle and also at higher RPM. It also stalls if I decrease the RPM quickly from above 2000 to lower including idle, It does not stall when increasing RPM quickly from idle to higher than 2000. I have seen an older topic on this subject but didn't see any solutions. Has anyone found what the problem is?
