clueless75
- Jan 30, 2015
- 102
I've got a 1969 Kiekhaefer Merc75 7.5hp 2 stroke red stripe motor serial no. 2535229 from Toronto, if that helps any. The motor hadn't run for over 10 years, yet it started up fairly easily, but there was no pee coming from anywhere. I took it in to a local marina repair shop for them to fix it as I didn't really have time. They said the impeller had burned up so they replaced that and other parts of the water pump. When I got it back the motor ran great with pee coming out, but I cant remember where, as it was a while ago. Then recently I decided to try it out again, but with only a little water and exhaust spitting out the front of the motor from the middle hole of three rectangular holes directly under the bottom cowl. I took off the lower unit to check if the impeller had gone, but it functioned properly. I took off the powerhead to check for a clogged water tube, only to find a bit of dirt. The yellowish seal connecting the engine block and water tube was slightly misshapen, but no other real problem. Taking off the powerhead only raised more questions as to where the water went after cooling the engine, and how it gets out to the tell-tale hole. I blew compressed air up the suspected tell-tale hole, but I could not feel any air coming out anywhere. There is another small hole right beside the "flush" screw on the side of the motor right under the bottom cowl that could also be a tell-tale hole as I blew compressed air up that hole to feel a little air coming out from a small hole on the engine block. Maybe the hole is blocked somewhere? Any help on where this pee hole is and how to access it would be greatly appreciated.
