Thanks for the info. There is a motor on e-bay 2000 Mercury 4 stroke 60 HP for about $1000. The description states "after about 5 hours of use the oil looks a little milky" A head gasket, or maybe even the condensation mentioned is a easy fix, a crack in the block is not worth it.The add also mentions the good compressions and good idle and running.Trying to make a decision
That's not condensation. Cracked block......what's the mechanism? Blown head gasket? My experience with them is that they blow between cylinders. Water that could leak out from cooling system usually blows out the exhaust. Additionally water in a combustion chamber acts like a solvent and the affected cylinders would be clean as compared to the others.
Tell you what. Without giving away your hand, ask the guy to pull the plugs and look at them. Ask him does he see any difference in the plugs in terms of combustion chamber deposits. If so, ask him which cylinders are which way....clean. If adjacent cylinders you might get lucky. If none, then a cracked block might be the culprit but again where is the mechanism? Unlike a sealed cooling system, even with the engine tilted up, or sitting at a marina in the water, it should drain the powerhead. Running with no cooling water?
Good luck,
Mark
