handymancraig
- Jan 23, 2015
- 1
if i disconnect the oil injection system, how are the bearings at the ends of the shaft going to be oiled/lubricated. i understand with premix, the pistons get oiled thru the carbs, but how do these bearings at the end of the crank get oiled??? when you look at the oil injection system the oil lines go from the oil tank pump across the powerhead to each individual pistons and the same oil line go to each end of the crank, so how or even do these bearings at the ends of the crank even get oiled when disconnecting the oil injection system on these mercs that seem to be entirely different from th evro systmes on the omc motors!!!! ssl thankx, handyman craig
