cc93cruiser
- Sep 25, 2011
- 9
Hello there first post here so sorry in advance if I use the wrong part name or if questions seem stupid no sense..Ok no that I wrote my disclaimer (ha), I was wondering if I can get some help as to were I can purchase some seals gaskets for a couple different areas that my outboard needs attention.. It is a 1982 80hp Mercury Mariner with a power tilt trim...I have a pic of one of the seal/o ring I need.. I believe it is called the strainer cover gasket.. Its a o ring that has failed and every time I pump the bulp to prime the engine fuel leaks from this area..
The other area that I have problems with is the lower Unit.. I turned on motor and immediately noticed that the motor wasen't spittin out water.. I turned it off and noticed that the holes on the bottom of the lower unit where the water enters there was rubber bits inside the holes. I am not sure if the impeller failed and fell towards the bottom of the lower unit (is that even possible) or is there a seal down there that failed.. Bottom line is that the motor is not spitting out the water and the lower unit has to be taken apart for a new impeller.. Here is a pic of the holes I am taking about where the rubber are in.. In the same pic you can see my last problem also.. There is hydraulic fluid leaking from one of the tilt trim cylinders .. I basically need a o ring kit to rebuild in there..
Guys I have been on my computer for the last 3 hrs without any luck on part number for impeller kit or tilt trim cylinder o ring kit.. I also need a part number for the o ring in the motor.. Any help would be much appreciated .. This is a good running motor and I don't want to lose faith or interest in it.. Please help.. Thanks in advance...
