ETX_Engineer_24
- Jan 1, 2015
- 7
Install "high dome" pistons on factory "low dome" mercury outboard?
I have an '81 Mercury 140 which I am in the process of rebuilding with new starter, trigger, 40-Amp stator w/ regulators, new CDI boxes, wiring, prop, impeller kit, and lastly but most importantly new pistons and piston rings. I purchased the high dome ported pistons not knowing that the motor came with factory low dome ported pistons. After reading multiple posts I've come to the conclusion that there is no problem with this application -if and only if - I use premium gasoline. Logically i was under the impression that the additional 0.1-inch eye brow height may interfere with the allowable clearance at the bottom of the stoke at TDC. So.... I placed the low dome and high dome inside piston hole No. 1 - the lateral distance from the bottom of the piston skirt to a pre-determined location on the block was exactly the same for both pistons; which in turn tells me that clearance is not a problem in this case and there >>should<< be sufficient space at TDC for either pistons to run the specified trajectory without the additional 0.1-inch brow to come into contact with the low dome block. Are there any other concerns of substance that I may be overlooking - prior to installing these "high dome" pistons? Has anyone ever put together such an application? and does it really create about +10 HP?
Thanks
Thanks
