My 2001 Mercury 115HP Salt Water Series (2 stroke 4 cylinder carby self mixing oil outboard) has recently been serviced and carbs tuned - it starts very easily and runs as well as ever. It idles reasonably well too (it's the model that drops to 2 cylinders for idle so sounds a bit rough as to be expected) - for a while at least. After idling for a bit (a few minutes) it will eventually stall, when this happens it will become difficult to start and not want to idle again.
I suspect that the cause is the spark plugs are fouling. The average water temperature here is only 14.36*C (approximately 58*F) - so pretty cold. I am running the standard spark plugs (NGK BPZ8H-N-10). I'm wondering if a hotter spark plug (such as 7 or 6 range) may help to prevent the fouling of the plugs at idle?
