will only go 7 mph, bogs down at about half throttle, any ideas? It runs smooth going slower than about 7 mph.
-And test for spark on all cylinders. Use an inductive timing light so you can check for spark while the outboard is under load. (have a look at the condition of the plugs while you have them removed to do your compression test):welcome: to iboats
Run a compression test and let us know
