I've been reading a lot on here and I have gotten a lot of great information, but now I need to ask a question. I am putting a boat together as a project. I picked up an old Sea Ark from a buddy for real cheap and then did some trading to get this (I believe 1976) Mercury 1150 SN: 4313322. It is just the motor and tilt or trim controller box looking thing. My problem is that I know nothing about boats whatsoever. This is my 1st boat ever and I'm worried I may have bit off more than I can chew. I don't have the external harness for it, or any controls, or any steering cables. The internal harness is definitely shot and of course it doesn't run. I was able to do a compression check on it the other day and cylinders 1-5 were between 109 and 114 psi. Is that acceptable? I couldn't access the 6th cylinder with it being so low in the housing. Also, I couldn't check the spark, which I'm guessing is because I was turning it over straight off of the starter stud. Is there anything else I can do to check and see if this motor is even worth repairing? I'm wondering if I should just part it out and buy new. Thanks for any help!
