Just picked up a Comet Twin in "like new" condition. Including the owners manual and original factory tags. Motor has very little run time. I can manually rotate the flywheel in reverse direction (CCW when viewed from the top) but can't rotate in the correct direction (CW when viewed from the top)either by hand of with the pull start. With the plugs out I can feel compression on both cylinders. The plugs are clean as a whistle too. Prop does not turn in reverse with the above manuever. The Motor does have the forward and neutral feature which I am not familiar with. Cannot understand for the life of me why this is happening. Hope one of you Merc Guru's can shed some light on this.
