americanworkmule
- Apr 1, 2012
- 7
Hi all was wondering if anyone out there had instructions for changing the water pump on a 25hp 2 stroke 2004 Mercury serial number 0T823006?
I tried to follow the instructions from 2010 that I found in a search:
http://forums.iboats.com/forum/engi...77798-25hp-2-stroke-mercury-water-pump-change
I was stopped at the first step because I cannot find a way to remove the "air resonator" off the front of the carb to get to the starter bolts.
I can't get a wrench or socket in between the housing to remove the bolts. Nor do I know what size to use.
http://oi57.tinypic.com/wmjf2t.jpg
http://oi57.tinypic.com/532rtf.jpg
http://oi61.tinypic.com/kaikat.jpg
