Sac A Lai
- Oct 16, 2014
- 1
I decided to change out my impeller on my outboard. I pulled the lower. I removed the cover for the impeller. I removed the impeller. I went and got the new impeller out of my truck only to find that it was way to small. I went back to the boat shop and got the correct Impeller. I have installed the new water pump kit but I am starting to doubt my self. Did I Curve the impeller the correct way. Should the fins on the impeller be bent Clockwise or counter clock wise? If you are looking at the bottom of the Impeller housing I have them bent Clock wise. Is this correct??
