R Dolph
- Sep 22, 2014
- 6
I have a 1982 Wellcraft with a 2002 150 XR6. The boat has been very reliable until yesterday afternoon. While cruising at about 4100RPM my motor slowly lost RPM's and shut it self off. It sounded like the motor was experienced heavy load and could not overcome the resistance. When in Neutral, the prop spins freely. Both batteries are fully charged. Oil and Fuel are new.
When I go to crank the motor, the starter engages, bendix gear moves into position but cannot turn the flywheel. When I take the flywheel cover off and use a rag to turn over then engine, I can only rotate it about 45 degrees before a hard stop.
NO Alarms went off,
Engine was "Peeing"
I am very concerned the motor somehow locked itself up.
Any guidance or suggestions are greatly appreciated & thanks for taking the time to read this.
Regards,
Randy
NO Alarms went off,
Engine was "Peeing"
Regards,
Randy
