Tex51
- Sep 4, 2014
- 46
My carbs are marked WMK-26-1 for the #1 and then #2 and #3 for the others so I would know how to put them back. Someone put kits in them sometime in the past. The engine would not idle and when I took them apart I found #1 has the brass tube from the carb opening with the plastic bar across the front from side to side was mutilated on the bottom end, #2 has a seat for the idle jet that has been wallowed out by the wrong screw driver along with all the external screw heads, and #3 I never bothered with that one yet.
I found a set of WMK-22-1. #2 and #3 that are complete and look to be in good shape. Changing from a WMK-26 set to a WMK-22 set will that work or have I purchased a nice set of fishing weights. Thanks Tex?
