Well, I have great news... I had sprayed some carb cleaner on the pickup fitting a few days ago, and had some time to work on the tank today. So I decided to bite the bullet and crank on the fitting. The cleaner must have did it, because I was able to get the pick up elbow fitting off without stripping anything. Which means that I can replace things without having to make bigger holes or makeshift epoxy.
But, as I pulled the pick up tube out, I noticed that there was nothing wrong with it that I could tell. There was no screen at the bottom, and the tube looked in relatively good condition. So, I'm a little baffled as to why things weren't working. There was definitely a problem from the tank somewhere (maybe the plastic pick up tube was letting air in the eblow fitting it was connected to? Or maybe there was some obstruction at the bottom of the tank that was clogging up the tube)
Anyway, my plan is to change out the pickup tube and vent tube. I'm going to cut the pick up about 3/4 shorter so that it is not sitting on the bottom of the tank in case there is debris in there.
My question - the elbow fitting - has 3/8" NPT fittings on the bottom AND the top (male on the bottom and female on the top) Most of the replacement pick up tubes have 3/8 NPT on the bottom, but 1/4" NPT on the top. Would there be a restriction of the fuel if I changed it to the 1/4" NPT?
Engine - 120hp Tracker/Force
