I have a 80-81 90 hp 6 cyl that appears to be stuck in forward. I removed the gear housing. The shift shaft in the gear housing rotates approximately 180 degrees, but regardless of position, the propeller only rotates clockwise when I rotate the driveshaft (clockwise). Any suggestions?
